Old 11-13-2014, 11:05 AM   #1
bouYaris
Drives: yaris 2007
Done the check wonder if done correctly
with Multimeter on 20V diret current
first check done with headlight connector (Disconnected from switch )
where the wire enters the back of the connector
Pin13 = 12.37
Pin 10 = 0
see picture
https://drive.google.com/file/d/0B-A...ew?usp=sharing
I put the connector back
with swith ON
pin13 = 12.28
pin10 = 12.28
with swtich OFF
pin13 = 12.36
pin10 = 0
bouYaris is offline   Reply With Quote
Old 11-13-2014, 12:51 PM   #2
Pin13 = 12.37
Pin 10 = 0
see picture
with swith ON
pin13 = 12.28
pin10 = 12.28
with swtich OFF
pin13 = 12.36
pin10 = 0
Perfect! OK - So, the power feed (fuse) is good. The switch is also good.
Now, let's jump to the back of the car and see what we see at the tail light connector.
With the headlight switch on, on the tail light connector measure the voltage between the green wire (red lead) and the white wire with a black stripe (black lead).
park lights not working koppe In Car Entertainment + Electronics (audio / video / alarm) 13 06-06-2025 02:24 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Rear break/STOP lights, tail lights are out, plate lights working? MzTyla DIY / Maintenance / Service 2 06-20-2013 07:56 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
