Old 11-21-2014, 10:06 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
It's pretty hard to tell much from that video. The mic seems to be picking up normal noises and making them sound worse than they are. It's normal to have some minor tick tick tick noises from the valves and injectors, but if you are getting knocking noises it's probably not good. If the noise is a metallic scraping noise, you may want to remove your drive belt and check. If the noise is gone, it's probably the waterpump impeller (usually they leak coolant prior to being that bad though).
If you can't get anywhere, try taking another video a little further away and I will listen again.
Cheers.
Weird Noise, unsure rpicard@demand-its.com DIY / Maintenance / Service 2 02-12-2013 03:52 PM
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
