Old 11-22-2014, 05:55 PM   #1
ex-x-fire
Take a long screwdriver (or even a wooden dowel) & place it at the accessories & the other part to your ear. The sound should transmit loudly on the noisy part. Or Remove the belt & feel for loose wobbly pulleys.
Old 11-24-2014, 09:28 AM   #2
vrizrak
Drives: 2007 Yaris Sedan
Removed belt. Not sure but looks like water pump's pulley little bit loose. Ran engine without belt and noise was gone. Nothing. Just clean engine sound. Turns out that was water pump. I'm planning to replace it this weekend. Will update after..
vrizrak is offline   Reply With Quote
Old 11-24-2014, 09:39 AM   #3
tmontague
tmontague's Avatar
my fiancee's wp went without leaking any fluid. The only way I knew was by a brutal noise. Most leak fluid first but not always, good advice to run without belt.
Old 11-24-2014, 10:04 AM   #4
vrizrak
No noise without belt... :)
Weird Noise, unsure rpicard@demand-its.com DIY / Maintenance / Service 2 02-12-2013 03:52 PM
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
