Old 11-24-2014, 12:20 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Glad you got it figured out. The water pump pulley should not rock at all. Some will slide in and out a SMALL amount (barely noticeable), but never rock. The bearing on the Yaris waterpump are a little weak so do not over tighten the belt when you replace the pump or you will be doing it again.
Cheers.
Old 11-24-2014, 12:26 PM   #2
vrizrak
Drives: 2007 Yaris Sedan
Cheers.
I've notice belt was over tighten. That probably what kill bearing. Well I will find out when I pull it from the car. Thanks.
vrizrak is offline   Reply With Quote
Old 12-02-2014, 09:49 AM   #3
vrizrak
Last weekend took water pump out for replace. It actually wasn't leaking but as you can see on picture it something. And it wasn't spinning freely. Feels like it ran over rubber or something. Anyway changed WP and not noise is gone. Except belt is squeaking when cold. :)
Weird Noise, unsure rpicard@demand-its.com DIY / Maintenance / Service 2 02-12-2013 03:52 PM
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
