Old 12-03-2014, 05:10 AM   #1
blindmanwatching
Drives: Vitz
Guys I need help with installing an OBD2 port. How do i install it to the new ECU? Anyone know how it is wired?
blindmanwatching is offline   Reply With Quote
Old 12-03-2014, 06:30 AM   #2
Did you get your hands on the wiring diagrams for the car that you grabbed the ECM from?
Old 12-03-2014, 12:33 PM   #3
blindmanwatching
Drives: Vitz
There are numurous wiring diagrams available online, for the 2001 celica, but I cant understand the whole concept of how the ECM is wired to the OBD2 plug. Need help with that.
Old 12-03-2014, 12:44 PM   #4
blindmanwatching
Drives: Vitz
Updates:
Updates:
Got the cooling system sorted out. Initially there was no thermostat installed and the temperature sensor was not plugged to keep the fans running at all times. Now 82C thermostat has been installed and temperature sensor has been plugged back on. As a result the LIFT is working perfectly now and the car accelerates like crazy when LIFT hits.(Video coming soon)
AC condenser has also been installed. But having problem with the AC compressor. The 1KR compressor which was fitted on this 2zz has cracked . probably the reason being the smaller pulley size. And i cant install the original compressor because there is no room for a larger pulley. Someone advise?
Old 12-03-2014, 06:34 PM   #5
Wiring to the OBD plug is typically very trivial. That vintage is ISO9141, so there is one (K line) wire that is the communications wire.
Pin 16 is constant 12 V power
Pin 4 and 5 are grounds
Pin 7 is SIL, which is a direct connection to the ECM
Pin 13 is TC, which is a direct connection to the ECM
An OBDII reader communicates with the ECM via pin 7, which is the "K Line". For a standard OBD reader, just 4,5,7 and 16 are needed. Pin 13 is a toyota specific diagnostic wire.
Old 12-04-2014, 11:52 AM   #6
blindmanwatching
Drives: Vitz
Thanks for the response.but on the ECM end, where will all these wires be connected? or will only pin 7 be connected to one of the pins on the ECM?
Old 12-04-2014, 06:42 PM   #7
7 and 13 are the only ones that connect directly to the ECM.
Old 12-05-2014, 12:33 PM   #8
blindmanwatching
Drives: Vitz
Ok. And are there any connections to the different sensors of the car...or does pin 7 and 13 provide all the data from the ECM to OBD2?
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
