Old 12-04-2014, 04:16 PM   #1
harda toenail
Drives: Want a yaris
Ive got this noise. Did you have to drop the engine to get the pump out?
harda toenail is offline   Reply With Quote
Old 12-05-2014, 08:42 AM   #2
vrizrak
Drives: 2007 Yaris Sedan
Yes. Thanks to Kou on his DYI. http://www.yarisworld.com/forums/showthread.php?t=12727
First I've put car on jack stands. There is 2 bolts and 1 nut. The nut is right under engine mount. You will need a long extender with 14mm socket. So remove nut first. Then place your floor jack and pump it until it hold engine a little bit. Then remove 2 bolts from the top. Also 14mm.
vrizrak is offline   Reply With Quote
Weird Noise, unsure rpicard@demand-its.com DIY / Maintenance / Service 2 02-12-2013 03:52 PM
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
