#1 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Don't worry about the wiring. Worst case you can run them in between the door and the interior panel and just through the space inside the fender to the front signal lights. those are where the OEM fender lights are wired anyway. Otherwise, insert it through the rubber boot and out to the junction box where you can get the +12V signal from Pin14 and Pin 31 from the 4B connector, and the ground from the nut by the kickpanel. The turn signals don't have polarity if they are not LED, either way you can interchange. |
#2 | |
![]() Drives: yaris Join Date: Jan 2014
Prius C signals
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
You have to wire them up , I grounded one wire to mirror bolt and the other ran through door to signal wires. Not hard at all . You have to use a dremel to shape mirror cover for signal light it took some time but its looks good when finished. I used a sharpie to outline shape of signal light.
#5 | |
Yeah they have to be cut to shape not hard to do sorry no pics. The signal light clips in the mirror. What I did was put signal in then put cover over light took sharpie to shape it and cut little by little and just kept repeating it . cover on shape with sharpie then cut over and over till cover fit perfectly.
I have a couple pics up on this forum u can check them out. Thanks
| will 2010 Yaris wheels fit 2012 Yaris? | yaris8888 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-24-2012 11:36 PM |
| What the 2012 Yaris should have been: Prius C | djct_watt | Third Gen Yaris General Discussion | 5 | 10-20-2011 08:12 PM |
