Old 02-24-2015, 01:43 AM   #5
davino1966
Drives: yaris
Prius C signals
Originally Posted by jcboy View Post
Don't worry about the wiring. Worst case you can run them in between the door and the interior panel and just through the space inside the fender to the front signal lights. those are where the OEM fender lights are wired anyway.
Otherwise, insert it through the rubber boot and out to the junction box where you can get the +12V signal from Pin14 and Pin 31 from the 4B connector, and the ground from the nut by the kickpanel. The turn signals don't have polarity if they are not LED, either way you can interchange.
They are not the same tried that but the Prius C signals fit you have to cut mirror cover to fit light and wire through the door. I bought used mirrors from junk yard. good luck
davino1966 is offline   Reply With Quote
will 2010 Yaris wheels fit 2012 Yaris? yaris8888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-24-2012 11:36 PM
What the 2012 Yaris should have been: Prius C djct_watt Third Gen Yaris General Discussion 5 10-20-2011 08:12 PM
