2ZR swap. DO IT! Ask how!
Maybe I don't understand the name correctly, but I think that in a throttle-by-wire system the throttle butterfly is the IAC valve. The throttle is driven by a servo motor, so the ECU can change the valve position automatically. A throttle-by-cable system can't adjust the butterfly, so some of them use a separate valve to adjust the idle air intake.
Perhaps someone else understands the difference better? Edit: here's a picture of an IAC system. The 4-bolt drive-by-wire TB doesn't have any of the stuff that bypasses the butterfly. |
#2 | |
![]() ![]() Drives: Yaris 2010 Manual Join Date: Dec 2010
| VALVE ADJUSTMENT INTERVAL | jemmah | DIY / Maintenance / Service | 7 | 10-12-2016 10:13 AM |
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| Valve lifter Problem !!! | Patocine | DIY / Maintenance / Service | 6 | 05-08-2012 11:09 AM |
| Ferrea valve upgrade kit | cali yaris | Micro Image | 4 | 07-28-2010 11:52 AM |
