Old 12-16-2014, 09:35 PM   #1
duendeverde
Drives: Yaris 2010 Manual
IAC Valve
Can anyone tell me where is the IAC located for a Yaris Sedan 2010? I want to clean this part since i bought m car used :/ want to clean all possible things related to Air like MAF Sensor (already cleaned), Throttle (already cleaned), put new hose, already install an AEM CAI, PCV valve (already cleaned) and the IAC valve (not yet cleaned)
Thanks
duendeverde is offline   Reply With Quote
Old 12-17-2014, 11:10 AM   #2
Should be connected right to your throttle body.
Old 12-17-2014, 11:43 AM   #3
duendeverde
Thanks, found it this morning
Old 12-17-2014, 11:44 AM   #4
tmontague
tmontague's Avatar
Let me know where abouts on the TB it is and how easy it was to clean. I forgot to clean it when I cleaned my TB this past spring.
Old 12-17-2014, 04:02 PM   #5
duendeverde
Sure, will do this saturday. I went to buy MOC Premium Throttle-Body & Air-Intake Cleaner at Toyota. One of the mechanics recommended me to remove the complete throttle body for optimum cleaning. The sensor should be attached to the TB but i haven't look around to see where it actually is
Old 12-17-2014, 04:31 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Maybe I don't understand the name correctly, but I think that in a throttle-by-wire system the throttle butterfly is the IAC valve. The throttle is driven by a servo motor, so the ECU can change the valve position automatically. A throttle-by-cable system can't adjust the butterfly, so some of them use a separate valve to adjust the idle air intake.
Perhaps someone else understands the difference better?
Edit: here's a picture of an IAC system. The 4-bolt drive-by-wire TB doesn't have any of the stuff that bypasses the butterfly.
File Type: gif 2007-07-10_143307_toyota_idle_air_control_system.gif (6.8 KB, 188 views)
Old 12-17-2014, 06:05 PM   #7
duendeverde
So what u r telling me is that an electronic throttle doesn't have that kind of valve, is just a throttle with the butterfly valve? I haven't disassemble the throttle yet :/
Old 12-17-2014, 06:44 PM   #8
Given what you've said in post#7, what is it that you actually found? I'm confused.
Old 12-17-2014, 06:58 PM   #9
duendeverde
Behind the throttle i saw like a black case, I thought that was the IAC since i haven't taken out the throttle yet. While looking through google images (electronic throttle) that black box
For example look the image below. Almost the same as the Yaris Throttle :/
Old 12-18-2014, 10:14 AM   #10
tmontague
tmontague's Avatar
I was actually thinking what Cranky stated. A drive by wire system would likely have an IAC built into it or the parts would just be redundant. I didn't take off my TB when I cleaned it but I didn't notice any extra valce or sensor. Mind you I also wasn't looking for one.
I'm not sure if you could theoretically clean the electronic throttle, but do you even need to as I don't think it would become dirty?
Old 12-18-2014, 10:32 AM   #11
duendeverde
True...but i have seen videos on Youtube about cleaning electronic throttles, the butterfly valve gets dirty on both side, I cleaned the outside of the butterfly so it would be great to clean the inside also
Old 12-18-2014, 10:48 AM   #12
CrankyOldMan
The PCV/breather system sends the excess crank case pressure back to the intake, between the MAF and butterfly. If you have blowby, you can get a LOT of soot on the butterfly valve. I take my TB completely off to clean it, but it's a lot easier with my custom intake setup than the stock airbox.
Old 12-19-2014, 09:32 AM   #13
tmontague
tmontague's Avatar
and that's why I have an oil catch can ;). Agreed though, depending on the amount of blowby it will all end up going through the TB
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 11:13 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 03:39 PM
Valve lifter Problem !!! Patocine DIY / Maintenance / Service 6 05-08-2012 12:09 PM
Ferrea valve upgrade kit cali yaris Micro Image 4 07-28-2010 12:52 PM
