Old 12-28-2014, 05:46 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There's a few options for Quaife, based on which gearbox/engine you have:
1.5 L 1NZ-FE > QDF15E
1.8 L 2ZR-FE > QDF21E
Both of these units are 8-bolt, but the 21E uses the larger output shafts of the 1.8 L model, and has a different shoulder diameter for the front ring gear. If you have a 1.5 L, you need the 15E.
Old 01-01-2015, 01:49 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
I guess that means one needs to be careful getting a used helical from JDM or EU. Good info. Thanks.
WTB: Limited Slip Differential FHT_Racing Willing to Buy by private party 0 10-10-2014 05:23 PM
KAAZ Limited Slip Differential Compatibility sheekeebut Performance Modifications 11 07-25-2014 12:18 AM
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 05:00 PM
TRD limited slip: part number? cali yaris Performance Modifications 9 08-13-2009 02:29 AM
Limited Slip regal Performance Modifications 13 03-20-2009 10:16 PM
