Old 12-31-2014, 11:15 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It might be advantageous to monitor a stock OCV for Hz (duty cycle) in normal operation to get a starting point on what values to set.
CT, you mentioned the ECM controls both ground and 12V wires. Does the valve work in two directions. Positive polarity for advance and negative for retard, or something to that effect?
Old 01-01-2015, 01:13 AM   #2
No. It actually does it all via pulsing the positive terminal. It is constantly being adjusted though, so less or more flow through it allows retarding or advancing the timing.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Replacement Radio + Steering Wheel Control Questions dinop In Car Entertainment + Electronics (audio / video / alarm) 0 07-07-2013 01:31 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
