I definitely would NOT block off the heater hoses. You will want to bypass instead. A lot of the coolant flow of the head passes through the heater hose, and you may get hot-spots if you block it off. The heater shut-off valves work well so would be the best bet. The ones linked to by Spooky should be the right size even (the vacuum controlled one is because the OE vehicles have vacuum controlled HVAC systems).
Cheers. |
| A/C or Heater Core leaking into passenger floor? | The Shape | DIY / Maintenance / Service | 3 | 03-23-2015 12:40 AM |
| Heater core hose | bankrobber | DIY / Maintenance / Service | 2 | 08-04-2011 07:38 PM |
| Rostra seat heater and lumbar support | sesmith | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-03-2009 08:51 AM |
