#1 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
Heater core hose
Can someone tell me what the hose is that goes under the engine cover?
Mine looks like it split but is still connected at the engine. I think it is a heater core line. |
That's the EGR hose, and if you look closely there is an outer protective layer, and that is probably what is split.
#3 |
Thanks CTScott... It is the outer layer that actually split and the clamp slipped off. Guess I gotta get a new hose. Gonna try to cut it and put clamp back on. Only need to cut 1/2 inch off I think.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| A/C or Heater Core leaking into passenger floor? | The Shape | DIY / Maintenance / Service | 3 | 03-23-2015 12:40 AM |
| vacuum hose / heater hose size | cali yaris | Performance Modifications | 12 | 05-17-2013 09:58 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
