Old 01-25-2015, 04:05 PM   #1
Ben_
Drives: 2010 Yaris Hatch
I emailed Mobil 1 and asked about their normal synthetic. They said it was designed to be changed every 10k or 1 year. I change every 5-8k depending on how I'm feeling lol. Also
Ben_ is offline   Reply With Quote
Old 01-25-2015, 04:09 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Don't forget on ur style of driving.. If ur hard on it, stop and go traffic etc
I use Mobil 1 and do my change at 5k tho I drive the crap out my Yaris lol
Old 01-25-2015, 10:39 PM   #3
nookandcrannycar
I've only done 20 oil and filter changes on my 2007 . Re my 2014, my plan is to do max 5k intervals.
Old 01-28-2015, 06:09 AM   #4
bronsin
bronsin's Avatar
Interesting. I expect if you drive a lot even 5k miles is too often.
Old 01-28-2015, 06:38 AM   #5
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
click and clack
The car guys on PBS would recommend 5k intervals with conventional oil. Anything less is a waste of oil and a boat payment for the quick lube. Oil and engines are much much better so this is not your grandad's Oldsmobile with a carburetor.
BTW, the Prius interval is 10k with synthetic and even then the oil looks real clean.
alanwagen is offline   Reply With Quote
Old 03-01-2015, 01:52 AM   #6
Jcp123
Drives: '00 Echo
I'd take Opa's Olds over modern cars any day. Modern cars are, shall we say, overrated. And this from someone with much love for my Echo.
Prius doesn't run its engine all the time, so longer OCIs make sense.
Jcp123 is offline   Reply With Quote
Old 03-01-2015, 07:01 AM   #7
alanwagen
Old
I can see a nostalgic affection for old cars, but changing plugs and rebuilding carbs all the time gets old. You would be lucky to get 100 k out of an old car without extensive repairs: shocks, front end, alternators. What I don't miss the most of old cars is the tweaking the automatic choke and hesitation, stalling and balking when the engine was cold. Back in those days, you had a good car when it would start on the second crank. And lets not even get in to the ignition points and setting the dwell.
Old 01-27-2015, 10:23 PM   #8
Ranger SVO
Drives: 2010 Yaris
My 2010 Yaris currently has 36,800 miles on it. I average just a little over 7000 miles per year. So the once a year oil change makes sense for me. I change the oil every May. I use Mobil 1 Extended Performance 5W30. Mobil states that this oil can go 15,000 miles so I'm in good shape changing the oil at around 7000 miles.
In my 2012 Honda Civic EX, I use Mobil 1 AFE 0w20. I change oil when the Maintenance Minder tells me to. That's typically around 8500 miles. According to Mobil 1 and Honda, that is not a problem with synthetics.
So I'll just keep going the way I'm going.
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Old 01-27-2015, 10:49 PM   #9
Yaristeve
Drives: 3-door hatch
I have a 2011 with 124k miles on it. I use conventional Castrol GTX, 5W30, OEM filters. First 100k miles or so, I changed it every 3k miles. Now I change it every 4k miles. I haven't had any problems. In fact, other than the oil/filter changes (and one air filter change), I haven't done anything else to my Yaris...
The reason I use 4k mile intervals is because sometimes I get busy and can't do it at or near the next interval so 4k mile intervals gives me a 1k mile buffer in case I am busy. I don't like going over the recommended 5k mile interval.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Oil Change Question... jayeh DIY / Maintenance / Service 4 03-05-2012 11:15 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
