Old 03-05-2012, 02:37 PM   #1
jayeh
Drives: '08 Yaris LB
Oil Change Question...
Hi Guys,
So, on all of my cars I've always filled my oil to the level that is mentioned in the manual. Usually this gets the level on the dip stick to about 50-75% of the normal level on the dip stick. I'm not concerned, but I've had some oil change places complain that I didn't supply enough oil to fill the car, and my damn mechanic decided to top up my expensive 0w30 German Castrol oil with some cheap shit and charge me for it, since the dip stick wasn't at the FULL mark. I do check my dip stick and the oil level doesn't change.
Whats everyones take on this?
Thanks
jayeh is offline   Reply With Quote
Old 03-05-2012, 03:49 PM   #2
Yaristeve
Drives: 3-door hatch
Hmmmm... when I put in the amount specified in the manual, I always end up more than the full mark...
Old 03-05-2012, 06:51 PM   #3
jayeh
I've never tried with a yaris, but with a 1.8L corolla and my old chrysler I've never hit the "full" mark.
I assumed its because the mid mark was cold, leaving room to expand when its heated....
Old 03-05-2012, 06:52 PM   #4
2007yariz
Drives: Yaris sedan
Thats because there will allways be some residual oil in the engine. Unless u let it drain for a week.
You should be fine if the level is between 2 dots.
2007yariz is offline   Reply With Quote
Old 03-05-2012, 11:15 PM   #5
Hershey
Around 1/2 a quart remains in the engine . Usually 3 and 3/4 quarts brings it to or slightly above the Full mark .
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
Oil Change Issue. Twistoffate0817 General Yaris / Vitz Discussion 56 05-05-2009 10:27 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
