Thanks for everyone's input. I guess a 6 speed transmission swap would be better, to keep the powerful 5th gear, and then have 6th when cruising on flat highway. I think I could get a used 6-speed for under $200. I could do a lot of the work myself, but I think I'd need a little expert help. If that sounds appealing to anyone in SoCal, let me know.
#2 | |
Regearing transmission 5th gear?
You would be cruising at about 3500rpm at 62mph with a 6 speed, so you won't get what you wanted to achieve. The echo has the longest final gear, I wonder if you could swap that in. That would bring you down to 2500rpm at 62mph. But let's not forget the Yaris is a heavier car, and doing this is still counter productive I think. |
#3 | |
2ZR swap. DO IT! Ask how!
| Transmission teardown | CrankyOldMan | DIY / Maintenance / Service | 19 | 03-04-2015 10:31 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| 5th gear messing up | N2scouting | DIY / Maintenance / Service | 1 | 09-07-2010 12:39 PM |
| longer 5th gear | german yaris | Performance Modifications | 36 | 11-06-2009 11:08 AM |
| Is using 5th gear at 40mph messes up my engine? | Syroyizhka | General Yaris / Vitz Discussion | 30 | 04-20-2009 07:59 PM |
