Old 02-02-2015, 02:09 AM   #1
spookybathtub
Drives: 2007 Yaris HB
Looks like the 6 speed has a larger final drive, which combined with the smaller 6th makes a larger ratio than the 5 speed in 5th. So what about taking a C160 and using the final drive gear from the C50? That should achieve much lower RPMs on the highway, but maybe not enough torque in 1st.
On the other hand, Toyota's stock gearing is designed to pair with the stock aerodynamics. With reduced drag, maybe it makes sense to just swap the 5th gear for a .725.
spookybathtub is offline   Reply With Quote
Old 02-02-2015, 06:31 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I think the two gearboxes are mechanically incompatible, specifically the differential. The C50 uses an 8-bolt ring gear, the C160 uses a 6-bolt. BlueVitz can confirm since he's done the swap. You would also have to find a pinion shaft for the 6-speed that came with the 3.722 final drive, and I don't think that exists.
Old 02-02-2015, 07:27 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Regearing transmission 5th gear?
You have to Frankenstein the 2 gearbox together to make a 6spd. It won't fit bolt on for sure.
And the Yaris uses the c150
Old 02-04-2015, 07:46 AM   #4
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
IllusionX you've been around long enough to know that the Yaris USES a C50... And Cranky is almost a master on this subject.
And talking about Frankenstein my trans gets installed today with 1st 3.166 2nd 1.904 3rd 1.310 4th 1.031 5th .815 and a 3.94 final with helical LSD special thanks to Cranky for info and help...
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 02-04-2015, 07:24 PM   #5
CrankyOldMan
Keep us posted on how it goes this time!
Transmission teardown CrankyOldMan DIY / Maintenance / Service 19 03-04-2015 10:31 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
5th gear messing up N2scouting DIY / Maintenance / Service 1 09-07-2010 12:39 PM
longer 5th gear german yaris Performance Modifications 36 11-06-2009 11:08 AM
Is using 5th gear at 40mph messes up my engine? Syroyizhka General Yaris / Vitz Discussion 30 04-20-2009 07:59 PM
