Old 02-02-2015, 06:07 AM   #1
Originally Posted by furinji.saiga View Post
Hello Scott,
Thank you for the previous confirmation. In the end, the trouble code happened due to the wrong wiring. I had a third electrician look into the matter. He redid the wiring and the trouble code went away. The P0715 code is gone now :)
However... the shaking during gear shifts did not go away...
The electrician hinted that the following are possible :
(i) the Primary and Secondary speed sensors not working as they should,
(ii) the catalytic converter has been incorrectly removed,
(iii) the resonator could be having issues.
Do you have an idea on what could be causing the shaking ?
Shaking during shifting would indicate more an issue with the transmission then something with the exhaust setup.
#input, #p0715, #sensor, #speed, #turbine
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 09:17 PM
