Old 02-02-2015, 06:31 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by spookybathtub View Post
So what about taking a C160 and using the final drive gear from the C50?
I think the two gearboxes are mechanically incompatible, specifically the differential. The C50 uses an 8-bolt ring gear, the C160 uses a 6-bolt. BlueVitz can confirm since he's done the swap. You would also have to find a pinion shaft for the 6-speed that came with the 3.722 final drive, and I don't think that exists.
Old 02-02-2015, 07:27 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Regearing transmission 5th gear?
You have to Frankenstein the 2 gearbox together to make a 6spd. It won't fit bolt on for sure.
And the Yaris uses the c150
Old 02-04-2015, 07:46 AM   #3
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
IllusionX you've been around long enough to know that the Yaris USES a C50... And Cranky is almost a master on this subject.
And talking about Frankenstein my trans gets installed today with 1st 3.166 2nd 1.904 3rd 1.310 4th 1.031 5th .815 and a 3.94 final with helical LSD special thanks to Cranky for info and help...
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 02-04-2015, 07:24 PM   #4
CrankyOldMan
Keep us posted on how it goes this time!
Transmission teardown CrankyOldMan DIY / Maintenance / Service 19 03-04-2015 10:31 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
5th gear messing up N2scouting DIY / Maintenance / Service 1 09-07-2010 12:39 PM
longer 5th gear german yaris Performance Modifications 36 11-06-2009 11:08 AM
Is using 5th gear at 40mph messes up my engine? Syroyizhka General Yaris / Vitz Discussion 30 04-20-2009 07:59 PM
