Old 12-03-2013, 03:14 PM   #415
harda toenail
Drives: Want a yaris
Is the clutch switch required? Is it's purpose to disengage the cruise when the clutch is pressed in?
harda toenail is offline   Reply With Quote
Old 12-03-2013, 03:18 PM   #416
The clutch switch is required for MT cars. The switch works the opposite of the clutch start switch, which is why it is a separate switch. It does disable CC when the clutch is touched, to prevent revving.
Old 12-03-2013, 09:30 PM   #417
harda toenail
Thanks for the quick reply. My dad wants cruise in his 07 MT LB yaris. I'll get the part ordered.
Old 12-03-2013, 10:01 PM   #418
I stock all of the cruise control parts at less than dealer or mail order prices, if you need anything.
Old 07-23-2014, 06:32 PM   #419
markanthonypr
Drives: 2007 Yaris Hatchback
Scott please check your inbox when possible. Thank you!
markanthonypr is offline   Reply With Quote
Old 02-12-2015, 03:57 PM   #420
Kirill
Drives: Yaris 2009 1.3 sol 100HP
Hi Scott,
I have the 2009 yaris Sol 100HP MMT transmission I will appreciate your help. could you check if it possible to install the cruise control on my car? I can send the VIN number ...
Kirill is offline   Reply With Quote
Old 02-12-2015, 08:11 PM   #421
Originally Posted by Kirill View Post
Hi Scott,
Unfortunately no European made Yaris prior to 2012 had cruise control. It was not until the 3rd generation with the 1.33L engine that Toyota added it.
Old 02-17-2015, 11:00 AM   #422
bronsin
bronsin's Avatar
I installed CC on my 09 Yaris in the summer of 09 according to CT Scotts instructions. It has worked flawlessly ever since.
I work building electronic devices for space and military applications. I told my supervisor about the CC mod in my Yaris and he looked alarmed.
"Paul, I cant BELIEVE you are modifying your brand new car by what some idiot on the internet is telling people to do!"
Old 02-17-2015, 07:05 PM   #423
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I also just finished installing the CC mod on my '09 Yaris according to CTScott's instructions 2 days ago. I am still baffled by how easy it was to enable this function.
Before, when I went to a dealership to ask if they could do it, they said they didn't even want to touch it.
"If it didn't come with it originally, we can't do anything about it." I would love to go back there now and just laugh at their faces.
I'll post some photos once I label all the buttons.
Thanks again CTScott! You are trully a Yaris mod master!
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 02-17-2015, 07:29 PM   #424
bairjo
Thanks again CTScott! You are trully a Yaris mod master! [/quote]
CTScott is def the man here. He is "THE DON" or should I say "THE SCOTT" of yarisworld. If he ever traded all three of his Yaris prototypes in for some other car...Yarisworld would not be as good as it is today..
bairjo is offline   Reply With Quote
Old 05-10-2015, 05:37 PM   #425
1972Dart
Drives: 2007 Toyota Yaris 4dr
Thanks a million to CTScott for all the help on my 07 Yaris! Cruise control works great!
1972Dart is offline   Reply With Quote
Old 05-04-2020, 09:28 PM   #426
Khalil
Drives: Yaris
Hi CTScott
I try to instal CC on my yaris 06 , but it did not work !!
Khalil is offline   Reply With Quote
Old 05-05-2020, 01:39 AM   #427
TcBryan
TcBryan's Avatar
Drives: 2007 yaris sedan base
I have found several at the local pick your part yards.
TcBryan is offline   Reply With Quote
Old 05-05-2020, 01:42 AM   #428
TcBryan
TcBryan's Avatar
CT Scott, I will trade stalks for wire harness for cc.
Old 11-27-2020, 07:03 PM   #429
nowe_service
Drives: yaris 2018
Has anyone installed CCS on the Toyota Yaris 2018 facelift
nowe_service is offline   Reply With Quote
Old 11-27-2020, 11:46 PM   #430
yarisa07hatchi
Drives: yaris 07 hatchi
where can i get ecu wire for cruise and wiring harness for clutch switch help
yarisa07hatchi is offline   Reply With Quote
Old 11-27-2020, 11:47 PM   #431
yarisa07hatchi
where can i get firewall piece i lost it
Old 12-28-2020, 02:37 AM   #432
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
So I read through the entire thread but didn't find a solution my issue (some similar cases but no resolution).
I have an 07 sedan, auto transmission, Canadian car. I went to perform this mod today, only to find that I have a factory wire (pin 40) at the ECM connection but no wire at the D3 connection under the steering wheel. No CC lights in the cluster either. Car has been dealer serviced since day 1.
Anyone else figured this one out?
EDIT:
Found the solution in another thread. The pin 40 wire seizes to exist after the firewall connection (AD4) on the drive side of the vehicle. Weird! See attached photo. Hope this helps someone out because it sure as hell gave me headache.
File Type: jpg DIY Cruise Control Wiring Issue Fix.jpg (132.7 KB, 69 views)
Kasbien is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
