Old 02-25-2015, 10:18 AM   #1
It would be messy, but would it not be advantageous at this point to disconnect the fuel line from the fuel rail?
If gas immediately flows out, you know your line is at least pressurized which is good. After that, if fuel still flows out of the line with key on or cranking, even better. Eliminates pump as a suspect would it not?
You know the coils are working as you can run the car by feeding fluid into the TB. That would leave you with an injector issue.
Old 02-25-2015, 07:06 PM   #2
He has verified that the injectors are not pulsing. The fuel pump is definitely not the issue.
Hard start in the morning 2008 Yaris CE volks_r_us DIY / Maintenance / Service 9 03-09-2018 04:18 PM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
2007 Yaris won't start. Camshaft sensor issue Countryman DIY / Maintenance / Service 14 03-11-2015 07:12 AM
Yaris and Viper 4204v remote start eeosman In Car Entertainment + Electronics (audio / video / alarm) 19 12-08-2013 03:49 PM
