Old 03-01-2015, 01:51 AM   #1
ucsmfu
Drives: yaris le
Right behind the battery is a giant grommet (~3" in diameter) for the main wiring harness. It has a lot of available space to punch through. I ran four #4 wires for my snowplow solenoid through it with room to spare. In the cabin it enters about a foot above the brake pedal.
will I need to remove the battery to access to the giant grommet ?
thanks
ucsmfu is offline   Reply With Quote
Old 03-01-2015, 10:10 AM   #2
thanks
It is easier if you do, but if you feed something through the grommet from under the dash, you can typically find it under the hood, and then attach the wire to it and pull it back through.
Old 03-01-2015, 10:59 AM   #3
ucsmfu
Drives: yaris le
I looked everywhere yesterday and I couldn't find the location from under the hood ?
I found the grommet inside the cabin. It's above the brake pedal. But didn't locate anything under the hood ? Thanks
Old 03-01-2015, 11:28 AM   #4
You can't see it without removing the Wiper tray and battery. I use a 1/8" plastic rod to poke through and snake out. What tends to happen is that you poke through the grommet and then hit the back of the plastic piece that supports the Y on the harness, or you poke though and hit the back of the battery.
Old 03-01-2015, 12:44 PM   #5
ucsmfu
Drives: yaris le
Attachment 55039
thanks for the picture CTScott, so I'll have to poke a hole through the grommet ? not able to remove the grommet itself ?
Trying to feed the temperate probe wire through for the CIPA mirror install :/
Old 03-01-2015, 01:40 PM   #6
Correct - You will poke through it. To remove it (to cut a little slit and slide the probe wire in without shoving the probe through) would require pulling the wiper tray off to give you full access to it.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Chevy Volt nemelek Off-topic / Other Cars / Everything else Discussions 8 04-02-2011 11:50 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
