Old 03-01-2015, 10:59 AM   #12
ucsmfu
Drives: yaris le
It is easier if you do, but if you feed something through the grommet from under the dash, you can typically find it under the hood, and then attach the wire to it and pull it back through.
I looked everywhere yesterday and I couldn't find the location from under the hood ?
I found the grommet inside the cabin. It's above the brake pedal. But didn't locate anything under the hood ? Thanks
ucsmfu is offline   Reply With Quote
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Chevy Volt nemelek Off-topic / Other Cars / Everything else Discussions 8 04-02-2011 11:50 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
