#1 | |
![]() ![]() Drives: '00 Echo Join Date: Mar 2014
Prius doesn't run its engine all the time, so longer OCIs make sense.
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Old
I can see a nostalgic affection for old cars, but changing plugs and rebuilding carbs all the time gets old. You would be lucky to get 100 k out of an old car without extensive repairs: shocks, front end, alternators. What I don't miss the most of old cars is the tweaking the automatic choke and hesitation, stalling and balking when the engine was cold. Back in those days, you had a good car when it would start on the second crank. And lets not even get in to the ignition points and setting the dwell.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Oil Change Question... | jayeh | DIY / Maintenance / Service | 4 | 03-05-2012 11:15 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
