It is easier if you do, but if you feed something through the grommet from under the dash, you can typically find it under the hood, and then attach the wire to it and pull it back through.
#2 | |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
I found the grommet inside the cabin. It's above the brake pedal. But didn't locate anything under the hood ? Thanks |
#3 | |
#4 | |
Trying to feed the temperate probe wire through for the CIPA mirror install :/ |
Correct - You will poke through it. To remove it (to cut a little slit and slide the probe wire in without shoving the probe through) would require pulling the wiper tray off to give you full access to it.
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Chevy Volt | nemelek | Off-topic / Other Cars / Everything else Discussions | 8 | 04-02-2011 11:50 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
