#1 | |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
I found the grommet inside the cabin. It's above the brake pedal. But didn't locate anything under the hood ? Thanks |
#2 | |
#3 | |
Trying to feed the temperate probe wire through for the CIPA mirror install :/ |
Correct - You will poke through it. To remove it (to cut a little slit and slide the probe wire in without shoving the probe through) would require pulling the wiper tray off to give you full access to it.
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Chevy Volt | nemelek | Off-topic / Other Cars / Everything else Discussions | 8 | 04-02-2011 11:50 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
