der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
since we have variable valve timing, it is always adjusting
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
You guys are getting ignition timing and valve timing confused. VVT-i is VALVE timing.
The knock sensor is there to retard IGNITION timing if it senses knock. You don't want to be moving the sensor around. That is about the stupidest thing you could do. Theoretically, yes the guy is right, but if there is no knock, then you will run the maximum ignition advance anyway, so moving the sensor is pointless. If you do knock, the sensor sees it and pulls the ignition timing back to protect the motor. If you move the sensor, then you keep knocking, and start eating away at your pistions. But you gained 2 HP while you did it. Hooray for dumb. |
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
2006 Red Blitzed RS 5-door |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| convenience vs. power package | jeff_o | General Yaris / Vitz Discussion | 25 | 10-17-2006 10:04 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 11:51 AM |
