Old 03-08-2015, 01:09 AM   #1
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
Is the FR FOG relay installed? In the US 3rd generation Yaris, it is built into the body ECU, but on the European market ones it is a separate relay.
I haven't done it. I was expecting pre-wired model to be equipped with it.
I know you've mention relay in the previous thread. I can't find it.
Where do I find it & what type of relay do I need?
karloslatynos is offline   Reply With Quote
Old 03-08-2015, 02:39 PM   #2
The relay is a common Toyota 90080-87021. It is located up under the dash (see the blue highlight below):
Old 03-08-2015, 02:42 PM   #3
karloslatynos
Ok, I've done my homework, had a look at relay location diagram (from www.toyota-tech.eu) and then went to my car to actually physically locate it (or at least if it isn't there (refferring to CTScott is not), its nest). After what I've seen I believe its located on top of the under the instrument panel fuse box.
To me it looks absolutely nightmare.
As the access to that is not available without removing other components, I think there are only two ways to get there: either remove the upper dash panel or somewhow pull the whole unit (under the instrument panel fuse box) down. I hope I'm wrong on this.
Compare to the 2nd gen. front fog relay location, this one is completely nonsense.
My understanding is that components like fuse, bulb, relay supposed to be accessable. Well done for the designer
I'm going to the dealer tomorrow & see what they say.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Yaris rear fog lights installation rtayyebi Cosmetic Modifications (Exterior/Interior) 1 11-14-2014 06:21 AM
