OK. All of the wires are where I would expect them to be.
The body ECU is involved in the process of switching the fogs on. The front and rear fog switches are inputs to the body ECU and it in turn drives the relays for them. From what you are seeing it may be that it has enough smarts to want them to truly be separate inputs. Try just jumping the front fog's dark green wire to the brown wire (which will allow the fronts to turn on) and then turn on the rears as well as see if they both stay on.
#2 | |
![]() ![]() Drives: 2012 Yaris TR 1.33 VVT-i Man Join Date: Nov 2014
When swapped over light green with dark green, none of fogs are able to switched on. |
#3 | |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Yaris rear fog lights installation | rtayyebi | Cosmetic Modifications (Exterior/Interior) | 1 | 11-14-2014 05:21 AM |
