Old 03-15-2015, 11:51 PM   #1
JEducate
Drives: 2009 5dr S series
I need help too! Mostly with the gas gauge.
Over the winter, my car's gas gauge was going back and forth to one bar to two bars left. It ended up stalling. Then, about a month ago, it said there was two bars left, and it stalled. I was hoping that it would be just frozen pipes. We have had a few warm days. I had to fill up my tank because it was stuck on three bars from the bottom. It will show it being filled up, but will stop at the third line. I read that it could be the indicators could be dirty. Any suggestions? Can I fix it myself, or do I have to go to a mechanic?
JEducate is offline   Reply With Quote
Old 03-16-2015, 06:51 AM   #2
That would be a a bit if a threadjack, as your post is completely unrelated to that of the O.P. Typically when a gas gauge does that it is due to the resistive strip for the fuel level sender either being dirty or being worn. You can try adding fuel system cleaner to the tank, but if that doesn't help, then you are looking at having to have the sender removed and replaced.
Hard start in the morning 2008 Yaris CE volks_r_us DIY / Maintenance / Service 9 03-09-2018 03:18 PM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
2007 Yaris won't start. Camshaft sensor issue Countryman DIY / Maintenance / Service 14 03-11-2015 06:12 AM
Yaris and Viper 4204v remote start eeosman In Car Entertainment + Electronics (audio / video / alarm) 19 12-08-2013 02:49 PM
