#1 | |
http://www.revzilla.com/common-tread...alve-adjusters |
#2 | |
My Yaris engine and my sons ECHO engine with 200k on it are QUIET. If your engine is noisy have the clearances checked. IF they are loose have them adjusted (murder) and see if the engine is now quiet. Its the only way to know!
#3 | |
#4 | |
In response to Bronsin's original post: I checked my clearance at 125,000km on my Yaris, all were within range. I am pullin the head off of my Echo next month to replace stem seals and clean out sludge. I will be checking the clearance before I pull it off and will replace the valve buckets if needed. The car has 347,000km on it so it will be interesting to see how the clearance is. It is only slightly louder than my Yaris other than the "new" water pump (replaced 1 year ago) that is now chirping on and off |
#5 | |
| 2007 sedan fuel pump not running and check engine light | nitrus10032 | DIY / Maintenance / Service | 23 | 08-23-2025 12:09 PM |
| Oil Pan Drain Valve | guy2can | DIY / Maintenance / Service | 16 | 01-06-2018 05:06 PM |
| PCV valve check ; Can it be done this | Hershey | DIY / Maintenance / Service | 7 | 03-31-2014 09:33 PM |
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 06:17 PM |
