thanks for the responses guys. I took a look at CanadianTire today and the only 30mm socket they have was a 6 point. Is a 6 point adequate for a 12 point nut, or does it increase the slippage and potential to strip? If a 12 point is highly recommended then I'll keep looking for one.
My second Q is can you just use an impact gun to remove the nut without having the pop out the indented part? |
#2 | |
| Wheel Bearing Replacement (FRONT) | justjesus | DIY / Maintenance / Service | 11 | 04-26-2014 07:38 PM |
| trouble with tie rod nut | BobTheYaris | DIY / Maintenance / Service | 3 | 04-07-2014 07:08 AM |
| AXEL Nut | FrankM | DIY / Maintenance / Service | 1 | 07-13-2012 06:29 AM |
| I CANNOT get the front strut nut off | naossoan | DIY / Maintenance / Service | 10 | 05-30-2009 03:11 PM |
| How to remove the Nut on the top of the shock tower | hystria | DIY / Maintenance / Service | 29 | 12-08-2006 09:30 PM |
