Old 04-06-2014, 03:04 PM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
trouble with tie rod nut
I'm putting my car back together after doing the clutch and I ran into a problem. The nut for the tie rod on the passenger side is stuck and I'm just spinning the threaded part. Does anyone know a way around this, I really don't want to replace it since that'll be another adventure, please help
BobTheYaris is offline   Reply With Quote
Old 04-06-2014, 09:35 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm assuming there isn't a hex socket on the top like with the sway bar links, is there? If so, I'm not sure how you would keep it from rotating, aside from damaging the threads with vice grips or pliers.
Old 04-06-2014, 09:45 PM   #3
I just looked at the spare steering rack that I have here, and the OEM tie rod ends on there do have the recessed hex socket on top of the threaded part. They had a bit of rust and dirt in them that made it hard to see.
Old 04-07-2014, 07:08 AM   #4
BobTheYaris
got the nut off and going out to pick up a die to chase the threads. thanks CT Scott, I'll have to escavate to find the hex hole
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
WTB Battery Tie Down Rod Altitude Willing to Buy by private party 3 01-07-2013 10:45 AM
Tie rods? devinlamothe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-05-2012 06:11 PM
Rod knock or Main bearing knock? jabranko General Yaris / Vitz Discussion 27 08-05-2011 11:14 AM
1NZFE K1 by Carrillo Rod interest list xBoosted Forced Induction Forum 20 01-20-2009 02:51 PM
