Old 04-02-2015, 05:33 AM   #1
AMOKS
Drives: 2008 HB
Hazard/Indicators permanently on & not flashing
Hey,
When I turn the car on, all the hazard lights come on, but don't flash.
Then when I press the hazard's button, nothing changes, still solid lights, just hear the hazard's clicking.
Same thing goes for trying to use the indicator, lights all stay solid just makes the clicking noise.
When I turn the car off, the hazards start flashing for a bit til they turn off.
Also if I turn it off, and push the hazards button they start flashing faster.
Any help would be greatly appreciated,
Brodie
AMOKS is offline   Reply With Quote
Old 04-02-2015, 06:59 AM   #2
Do you by any chance have an aftermarket alarm or remote starter?
If so, I would suspect that being the cause. If not, it may be the flasher module for the signals that is bad. It is a larger plastic block on the under-dash fuse panel.
Old 04-02-2015, 07:26 AM   #3
AMOKS
Drives: 2008 HB
Yeah I do have an aftermarket alarm, I don't know much about it though
The car was previously a security car that I purchased from a car yard, So I only have a small booklet for the alarm which is from a local company
This only just started happening as well
Thanks for the reply,
Brodie
Old 04-02-2015, 07:16 PM   #4
Brodie
In that case, I would definitely thing the alarm is the issue.
Old 04-05-2015, 11:37 PM   #5
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Yes, it is. I have a similar aftermarket keyless entry system and the same thing happens to me when I enter my vehicle using only the original car key. (not pressing the unlock button on the remote)
The system is still armed and believes someone has broken in the car, thus when you turn your aux. on, the immobilizer allows your engine to turnover and start, but your alarm will sound and hazards will start flashing. (like me, i'm guessing you don't have a siren installed)
If only there was a way to integrate the two of them...
random cel flashing malibuguy General Yaris / Vitz Discussion 0 08-30-2013 08:57 PM
How far can you get when your final bar of gas is rapidly flashing? JerseyJeff84 Fuel Economy Forum 19 07-24-2013 08:38 PM
2001 Yaris flashing hazards when ignition off!!!?! 4odh4n DIY / Maintenance / Service 7 01-20-2012 06:51 AM
Anyone tried POR-15 to permanently stop rust. marcus General Yaris / Vitz Discussion 12 06-17-2011 12:07 AM
flashing head light.. djgab101 Cosmetic Modifications (Exterior/Interior) 7 02-23-2009 09:24 PM
