Old 08-30-2013, 07:57 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
random cel flashing
I should begin with the first incident...
a few months ago I was in the mountains for my honeymoon while acellerating full throttle up a steep on ramp I had to drop in power followed immediately by flashing check engine light. then I had a steady light on which turned out to be a misfire code so I replaced the plugs with fresh NGK iridiums later that week the car had a little under 60,000 miles. All has been well.
today i was in heavy excess of traffic and just when I thought I should probably still turbo this car traffic suddenly cleared and I did a third gear pull. As I approached redline...the car studdered lightly and then started flashing the CEL at me so I'll let off and coasted for a moment...then i went full throttle again and then it did it again and I did it two more times what's the same results.
I tried again a few more times later down the road but I was only in 5th gear and all was well mind you the car has about 63,000 miles is this a coil pack issue?? I have no constant CEL so have nothing to scan.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
CEL afer oil pressure light andysong DIY / Maintenance / Service 8 03-06-2020 02:57 PM
Help! CEL P0420 kwkshft DIY / Maintenance / Service 10 03-15-2014 09:10 PM
2001 Yaris flashing hazards when ignition off!!!?! 4odh4n DIY / Maintenance / Service 7 01-20-2012 05:51 AM
HELP! Random Engine Cut-Off!!! YarisPR General Yaris / Vitz Discussion 12 04-07-2011 12:41 AM
Car shaking cel flashing? jamal1984 General Yaris / Vitz Discussion 7 10-16-2010 06:31 PM
