Old 04-17-2015, 08:12 AM   #1
09heavychevy
Drives: 2007 Toyota Yaris
Left Wheel.
inspected the backing plate, did not see any bent or contact with rotor, bent it a little more away from the rotor just for good measure.
no change, same grinding noise
09heavychevy is offline   Reply With Quote
Old 04-17-2025, 07:28 PM   #2
primelegend12
Drives: 2010 Yaris 2D Hatchback
Originally Posted by 09heavychevy View Post
Left Wheel.
May I ask if you found the source of the grinding noise? and what was the issue? TIA
primelegend12 is offline   Reply With Quote
Grinding noise when turning sharp right roblobstuhh DIY / Maintenance / Service 14 07-08-2015 09:28 AM
grinding noise during acceleration and air condition problems menz DIY / Maintenance / Service 7 03-28-2015 11:47 PM
Grinding noise in reverse NickNickNick DIY / Maintenance / Service 14 03-15-2013 03:10 AM
Yaris makes a grinding noise while turning jonathankoji DIY / Maintenance / Service 7 07-06-2011 07:01 AM
ABS?, Grinding Noise When Brakes Are Locked!??? p0pNfr3sh DIY / Maintenance / Service 3 03-03-2010 05:22 AM
