#37 |
![]() Drives: yaris 2sz-fe Join Date: May 2009
Thanks a million CTScoot!
Had to go through the procedure a couple of times until i realized that the door had to stay open between some of the steps |
#38 |
![]() Drives: Toyota Yaris 2007 LE liftback Join Date: Apr 2015
Hi,
I just bought a 2007 Toyota Yaris liftback... I have a remote car starter but the lock/unlock function doesn't work. It makes the lights flash but it doesn't unlock the doors. I have tried to reprogram it by following CTScott's post, but the doors dont lock/unlock at the end of the procedure. Any help would be greatly appreciated! Thanks Kim |
#39 | |
Do you have a separate remote for the remote starter and the genuine Toyota keyless entry remote?
#40 | |
Do you think they could have only installed the remote car starter and "forgot" or purposely decided not to install the lock/unlock feature? Cuz when I press on that button it makes the car lights flash instead of locking/unlocking the doors. |
#41 | |
It is very possible/likely that they did not hook up the lock/unlock. Does your car have power locks?
#42 |
#43 |
OK. In that case I would pop open the cover under the steering wheel and see if you can find the module for the remote starter to see what is and is not connected to it.
#44 | |
#45 |
Here are the photos :
https://plus.google.com/u/0/photos/1...92190491869509 https://plus.google.com/u/0/photos/1...92190491869509 Does this look like a remote car starter module? Last edited by kimouette; 04-19-2015 at 10:01 AM. |
#46 | |
#47 |
I cant find the brand name on the module.
Here's a photo of what I see : https://plus.google.com/u/0/photos/1...92190491869509 Unfortunately with these information I cant find any manual! |
#48 |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
This may help and here is a recall on that model.
http://www-odi.nhtsa.dot.gov/acms/cs...E045-5133P.pdf |
#49 | |
http://autostart.ca/AboutUs.aspx
#50 |
Ok so I found the wiring plan : http://autostart.ca/asdocs/2W_FM_LED..._en_h50s44.pdf
Which confirms the lock/unlock is simply not wired. Who would do that?? I mean break his back wiring a remote start and stop for a coffee and say "hmm lets call it a day". Would you recommend a newbie like me to buy the wires and plug them in? Or should I leave that to a professional and pay the price? |
#51 |
![]() Drives: 2010 Vitz 9AE Join Date: May 2015
nvm
#52 |
![]() Drives: '08 3DrLB. Join Date: Sep 2010
Had this happen recently. Ended up pulling the battery cable and that corrected the issue. Probably the airbag recall was the last time the cable was taken loose about eight years ago. I have a ten year old optima in there.
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 02:32 PM |
| Help! Keyless entry on a 2007 liftback?! | sd_007 | DIY / Maintenance / Service | 4 | 05-28-2009 05:01 PM |
| keyless entry? / security? | mem | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 10-22-2008 02:29 AM |
| Aftermarket Keyless Entry - How does it affect the Warranty? | aerock19 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-07-2007 03:11 PM |
| I want keyless entry!!! | Lillydot | General Yaris / Vitz Discussion | 7 | 03-20-2007 11:46 PM |
