![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
I know you are in Canada, so not sure if this applies where you live, but many chain tire shops in the US offer free alignment checks. I know this is a way to get your car on the rack so the tech can inspect the car and then try to sell you added services for your car that you may need or not need, but you can always say no, and in the process, find out if the suspension work you have done has change your alignment to an out of spec condition. It doesn't take much, a degree or two, to cause some pretty bad tire wear.
#2 | |
![]() ![]() ![]() Drives: 2008 lowered yaris on 17's Join Date: Feb 2015
#3 | |
Even though it turned out to have poor alignment (didn't care because it tracked straight and got so few miles I replaced the tires due to rot) they didn't do anything more than let me know I should consider an alignment when I picked up the vehicle. No heavy sales pitch or anything. |
| No factory rear alignment gear? | bad | DIY / Maintenance / Service | 6 | 01-28-2015 12:21 PM |
| Alignment Question | gsf1200m | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-16-2009 10:35 AM |
| WOW What a difference an alignment makes!! | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-12-2009 05:29 PM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 07:01 AM |
