Old 05-01-2015, 05:08 AM   #3
beaker
Drives: 07 Yaris 3 door
I know you are in Canada, so not sure if this applies where you live, but many chain tire shops in the US offer free alignment checks. I know this is a way to get your car on the rack so the tech can inspect the car and then try to sell you added services for your car that you may need or not need, but you can always say no, and in the process, find out if the suspension work you have done has change your alignment to an out of spec condition. It doesn't take much, a degree or two, to cause some pretty bad tire wear.
beaker is offline   Reply With Quote
No factory rear alignment gear? bad DIY / Maintenance / Service 6 01-28-2015 12:21 PM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 10:35 AM
WOW What a difference an alignment makes!! YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-12-2009 05:29 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
