![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
2011 , too bad , no update ... I am having a sound when turning left "Tac Tac Tac ", the more weight put in the curve ; the louder the "Tac Tac Tac" ,nothing in a straight line , just quiet as can be , it does it equally under load or breaking , or just coasting thru the curves was wondering if it was a half shaft , or wheel bearing ..... sounds like it is coming from front right side but that can be deceiving , sometimes other rattles sounded like they were coming from the front ,and turned out it was something in the back of the car ... any expert opinions ?? 2007 from May 2006 190,000 KM |
#2 | |
no ripped boot , all looks good down there
low speed, high speed ; = "ta ka ta ka ta "..... the more weight applied to the wheel , in the curve , the louder the "ta ka ta ka ta " in the past I have had cv joints go bad and there was a difference in the loudness of the sound when you accelarated compared to just coasting thru a curve that is why I was hoping someone else had the same behavior described . I'll look into this during the next weeks and report results. Thanks for reply CTScott |
Found my problem ..
sort of thread jacking ... but it is the same subject ![]() . I knew my sound was not the same as described by the original poster , he described very well with his words ' a growling and resonating noise'' and that sounds like a wheel bearing. . my '' scratch , scratch ,scratch '' noise was different , and only when turning left . turns out it was a brake part , sorry I did not take a picture , but it is the part of the Caliper that does not move , the part that is held by 2 17mm bolts , where the rotor almost touches at the bottom , when turning , well mine touched just a bit , and it was enough to make of huge sound , when the brake pads leave a lip on the outer part of the rotor , that lip gets rusted and creates a crust , that crust rubbed on the caliper part , took the grinder and removed the lip all around the rotor , then removed the part held by 2 17mm bolts , the brake pads stay attached to that part , so no need to remove them , and I grounded off some metal , sort of a defect in the molding of that cast Iron part , a crest in the metal , no more noise . . Hopes this helps someone else some day Last edited by Kazimodo; 07-12-2015 at 10:05 AM. |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Installing Rear Wheel Bearing Hub | brad4ds | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 07-22-2011 06:34 PM |
| Front Wheel Bearing Failure | craigq | DIY / Maintenance / Service | 4 | 08-17-2007 07:26 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
