#19 |
I have the same noise coming from drivers side front. I believe it is the wheel bearing starting to go bad and sticking a little it is annoying but not in a rush to fix.
#20 |
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
Thanks Kou , I was thinking the same thing
ANNOYING , tolerable for now , too busy .
#21 |
I am going to purchase a used spindle then install a new hub and bearing in that so it will be an easy job when I feel the need to change out the bad one.
#22 |
Found my problem ..
sort of thread jacking ... but it is the same subject ![]() . I knew my sound was not the same as described by the original poster , he described very well with his words ' a growling and resonating noise'' and that sounds like a wheel bearing. . my '' scratch , scratch ,scratch '' noise was different , and only when turning left . turns out it was a brake part , sorry I did not take a picture , but it is the part of the Caliper that does not move , the part that is held by 2 17mm bolts , where the rotor almost touches at the bottom , when turning , well mine touched just a bit , and it was enough to make of huge sound , when the brake pads leave a lip on the outer part of the rotor , that lip gets rusted and creates a crust , that crust rubbed on the caliper part , took the grinder and removed the lip all around the rotor , then removed the part held by 2 17mm bolts , the brake pads stay attached to that part , so no need to remove them , and I grounded off some metal , sort of a defect in the molding of that cast Iron part , a crest in the metal , no more noise . . Hopes this helps someone else some day Last edited by Kazimodo; 07-12-2015 at 10:05 AM. |
#23 |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Installing Rear Wheel Bearing Hub | brad4ds | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 07-22-2011 06:34 PM |
| Front Wheel Bearing Failure | craigq | DIY / Maintenance / Service | 4 | 08-17-2007 07:26 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
