I just re used the metal gasket that came stock w/ my Yaris since the paper crappy one it came w/ ripped.
I would never try this job without removing the passenger side engine mount. It makes your job very easy. Put car up on Jack stands, put a jack w/ wood block on jack and put jack under oil pan, remove engine mount, use the jack to raise and lower the engine to make all the bolts easily accessible. I wouldn't recommend the motomaster Asian long life, it is not the same ingredients as the OEM toyota. However Canadian tire now has the pink toyota stuff that is the exact same ingredients as toyota's and it is made by a company called OEM. It is good for 5years/250,000km and I used that in my Echo and Yaris, works great. |
#2 | |
![]() Drives: 2007 Toyota Yaris sedan Join Date: May 2015
| water pump | misterfly | DIY / Maintenance / Service | 8 | 01-07-2015 03:55 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| Hmm my water pump failed again!!!! Could it be the pulley?!?! | YarisSedan | Performance Modifications | 64 | 10-05-2009 09:32 PM |
