Old 12-07-2014, 05:14 PM   #1
misterfly
uk hardcore for life
Drives: toyota yaris 2008 sedan
water pump
Hi Guy, since yesterday my yaris do the noise from the water pump without any leak, i want to know if i can run the car 10 or 12 day before i got the new pump or i need to park completly the car, i do 25 km by day.
Thanks
misterfly is offline   Reply With Quote
Old 12-07-2014, 06:09 PM   #2
shepd
Drives: 2007 Yaris 5 door RS
Anything can happen. Watch for leaks and overheating. Unfortunately our cars don't have an engine temperature gauge, just an idiot light, so I would be less likely to take a risk.
A car with a completely broken waterpump can overheat within 2 km.
All that being said, I drove a car with a damaged (but not broken) waterpump for a few weeks without any problems. However, if it decided to give up in the middle of any of those drives, I would have been stranded and needed a tow back.
shepd is offline   Reply With Quote
Old 12-07-2014, 09:40 PM   #3
harda toenail
Drives: Want a yaris
You're in Canada and it's winter. You should be ok for a couple days. You will need to worry about that bearing shearing and sending parts throughout your cooling system though.
Have you loosened the belt to see if the noise stops?
harda toenail is offline   Reply With Quote
Old 12-08-2014, 06:59 AM   #4
bronsin
bronsin's Avatar
Probably you will be OK.
If it was my car I would drive it.
But have a plan in case something bad happens!
Good luck!
Old 12-08-2014, 08:31 AM   #5
ex-x-fire
Be careful, the water pump impeller might be grinding on the housing inside.
Old 12-09-2014, 05:56 PM   #6
misterfly
Hi Thanks for your help, finally i have find a new aftermarket pump and i will install tomorrow. I have send the car to a garage and is only the pump, i will talk to the mecano if he see some grinding in the housing.
Old 12-10-2014, 09:59 AM   #7
esse10
Drives: 2009 yaris 2 door
cautious
You can drive it but watch for leaks/puddles under the car every time you park it because they have a weeping hole and when that starts to leak...well brother you better change it out ASAP or you'll find yourself stranded.
Old 12-10-2014, 11:37 AM   #8
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
I hate that temp light.
When the water pump fails no coolant is pushed past that sensor so it just reads the temperature on the outbound coolant line which stays cool and will read hot when you take a corner that moves the hot coolant to the sensor.
So essentially if it fails the only way you can know is if you have the heat on and it starts blowing cold.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 01-07-2015, 04:55 PM   #9
screenprinter
Drives: 2010 Yaris 4-door Sedan
Just replaced my Water Pump. Sounded like Marbles in the engine.
One week I took my car in for Oil Change and Tire Rotation. Two weeks later the Water Pump started making the noise. Of course I thought they did it, lol. Next my brakes started feeling like a sponge.
I drive a lot, but come on. lol.
screenprinter is offline   Reply With Quote
water pump change 2sz-fe finnpoulsen DIY / Maintenance / Service 5 03-25-2020 11:20 AM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 09:05 AM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 01:33 PM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 10:26 AM
