![]() ![]() Drives: 2013 Yaris LE 5Dr Join Date: Nov 2014
Wobble/pulse/vibration at speed while driving.
I've got a vibration at 60mph and above that feels like I've got a bent rim or something. My steering wheel doesn't vibrate, but on occasion my pedal does.
How do I determine what the cause is for free or little money? I'm hoping it's a bent rim, because I really want to get better rims.
Looking for fun! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
Most likely you need some wheel balancing done.
A bent rim will manifest itself at speeds lower than 60. An unbalanced wheel often needs the higher speeds to be really noticeable. Sent from my iPhone using Tapatalk
The dude at tirediscounters says my tires are very unevenly worn, and I noticed at least two of my tires are at the wear indicators. Maybe that has something to do with it?
Looking for fun! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Could very well be it, I'd purchase an alignment so the uneven wear won't happen again (unless it's due to improper inflation), and then install new tires. Should fix things for you, as well as let you know if any of your wheels happen to be bent.
I'm concerned it's coming from my engine. I notice it only when accelerating or when engine is using the most torque. Could I have bent valves?
Looking for fun! |
#6 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Not your engine. lol |
Getting new tires is like $500-$600 around here. That's a lot of money for us. Would getting new rims that are wider and new wider tires maybe also help with highway stability?
Looking for fun! |
Where is 'around here'? If you live in the continental states you should be able to get quality tires for around $70 each. Discounttiredirect .com is an excellent source for tires. Sent from my iPhone using Tapatalk
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I would also suggest checking the condition of your brakes and maybe run-out. Just to make sure you don't have any wheel bearing issues.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
You can get a decent tire for $70 a pop, but for a little more you can get a significantly better tire. I think $500-$600 is a good estimate if you're looking at top shelf tires and considering tax, installation and maintenance/warranty packages.
I know that, but OP does not sound like a top shelf kind of guy. More the type that just needs to keep it rolling.
Sway bar, first thing to do on these cars!
#14 |
![]() Drives: '07 3d, '10 3d, '12 3d Join Date: Jun 2015
Swap tires front to back and see if the nature of the vibration changes (seems to be coming from somewhere else, gets better/worse, etc)- if it does that indicates unbalanced wheels/tires are the likely culprit.
#15 |
Thanks. And yeah, I'm just looking for some inexpensive fixes. I went ahead and ordered tires from CostCo, we'll see if that fixes it. I appreciate everyone's feedback!
Looking for fun! |
#16 |
New tires fixed the problem.
Looking for fun! |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Sounds like some tire cowboy hit your fronts with an air gun, over-torqued the lugs and distorted your rotors. Common problem with today's light-weight brake rotors.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| 2014 LTA Land Speed Harvest Event | fnkngrv | Tracking, Racing, Auto-X Forum | 8 | 09-12-2014 06:20 PM |
| I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe | PETERPOOP | Off-topic / Other Cars / Everything else Discussions | 21 | 05-16-2010 04:19 PM |
| Ford has a good idea. MyKey | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 16 | 03-19-2010 02:17 PM |
| Getting used to driving small cars... | orangepeels | General Yaris / Vitz Discussion | 19 | 05-06-2009 01:45 PM |
| Bad Driving Techniques | Altitude | General Yaris / Vitz Discussion | 10 | 02-10-2009 06:26 PM |
