Old 06-01-2015, 01:43 PM   #1
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
Wobble/pulse/vibration at speed while driving.
I've got a vibration at 60mph and above that feels like I've got a bent rim or something. My steering wheel doesn't vibrate, but on occasion my pedal does.
How do I determine what the cause is for free or little money? I'm hoping it's a bent rim, because I really want to get better rims.
Looking for fun!
hondajt is offline   Reply With Quote
Old 06-01-2015, 06:28 PM   #2
Most likely you need some wheel balancing done.
A bent rim will manifest itself at speeds lower than 60. An unbalanced wheel often needs the higher speeds to be really noticeable.
Old 06-02-2015, 04:53 PM   #3
hondajt
hondajt's Avatar
The dude at tirediscounters says my tires are very unevenly worn, and I noticed at least two of my tires are at the wear indicators. Maybe that has something to do with it?
Looking for fun!
Old 06-02-2015, 05:44 PM   #4
33OH
Drives: '08 Yaris
Could very well be it, I'd purchase an alignment so the uneven wear won't happen again (unless it's due to improper inflation), and then install new tires. Should fix things for you, as well as let you know if any of your wheels happen to be bent.
Old 06-13-2015, 09:26 AM   #5
hondajt
hondajt's Avatar
I'm concerned it's coming from my engine. I notice it only when accelerating or when engine is using the most torque. Could I have bent valves?
Looking for fun!
Old 06-13-2015, 11:30 AM   #6
Rigaud
Drives: 2009 Yaris
There you go....99.9% chance that's your problem.
Not your engine. lol
Old 06-14-2015, 11:44 AM   #7
hondajt
hondajt's Avatar
Getting new tires is like $500-$600 around here. That's a lot of money for us. Would getting new rims that are wider and new wider tires maybe also help with highway stability?
Looking for fun!
Old 06-14-2015, 12:50 PM   #8
Where is 'around here'? If you live in the continental states you should be able to get quality tires for around $70 each.
Discounttiredirect .com is an excellent source for tires.
Old 06-14-2015, 02:05 PM   #9
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I would also suggest checking the condition of your brakes and maybe run-out. Just to make sure you don't have any wheel bearing issues.
Old 06-15-2015, 03:29 PM   #10
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
You can get a decent tire for $70 a pop, but for a little more you can get a significantly better tire. I think $500-$600 is a good estimate if you're looking at top shelf tires and considering tax, installation and maintenance/warranty packages.
Old 06-15-2015, 08:05 PM   #11
I know that, but OP does not sound like a top shelf kind of guy. More the type that just needs to keep it rolling.
Old 06-15-2015, 09:16 PM   #12
Rigaud
Drives: 2009 Yaris
Sway bar, first thing to do on these cars!
Old 06-16-2015, 02:12 PM   #13
ern-diz
ern-diz's Avatar
I hear you
Old 06-22-2015, 03:32 PM   #14
unadilla66
Drives: '07 3d, '10 3d, '12 3d
Swap tires front to back and see if the nature of the vibration changes (seems to be coming from somewhere else, gets better/worse, etc)- if it does that indicates unbalanced wheels/tires are the likely culprit.
unadilla66 is offline   Reply With Quote
Old 06-22-2015, 05:36 PM   #15
hondajt
hondajt's Avatar
Thanks. And yeah, I'm just looking for some inexpensive fixes. I went ahead and ordered tires from CostCo, we'll see if that fixes it. I appreciate everyone's feedback!
Looking for fun!
Old 06-26-2015, 12:27 PM   #16
hondajt
hondajt's Avatar
New tires fixed the problem.
Looking for fun!
Old 06-26-2015, 11:13 PM   #17
MUSKOKA800
MUSKOKA800's Avatar
Sounds like some tire cowboy hit your fronts with an air gun, over-torqued the lugs and distorted your rotors. Common problem with today's light-weight brake rotors.
2014 LTA Land Speed Harvest Event fnkngrv Tracking, Racing, Auto-X Forum 8 09-12-2014 06:20 PM
I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe PETERPOOP Off-topic / Other Cars / Everything else Discussions 21 05-16-2010 04:19 PM
Ford has a good idea. MyKey *MAD DOG* Off-topic / Other Cars / Everything else Discussions 16 03-19-2010 02:17 PM
Getting used to driving small cars... orangepeels General Yaris / Vitz Discussion 19 05-06-2009 01:45 PM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 06:26 PM
