Old 06-30-2015, 06:39 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by 2009Toyotoad View Post
BTW, I wonder why the coolant sensor isn't signaling low coolant levels. it should also be tested/replaced with a new one.
That sensor simply reads temperature, not level. Same goes for oil, it only reads pressure, not level. There's a reason they're called idiot lights, by the time they turn on damage has probably already occurred.
Coolant if leaking from the heater core will more than likely just drain out of the same drain that condensed water leaks from for the A/C.
'02 Echo cooling fan potential problem tmontague DIY / Maintenance / Service 2 04-07-2015 10:06 AM
A/c fan operation. mrpj Third Gen Yaris General Discussion 1 03-29-2015 06:57 AM
No power to engine fan ihateyaris DIY / Maintenance / Service 2 03-26-2015 06:33 PM
Cooling fan starts at 207*F Ioannis DIY / Maintenance / Service 1 11-03-2014 09:09 AM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
