Old 07-18-2015, 03:46 PM   #1
valchrist90731
Drives: 2007 toyota yaris sedan
Originally Posted by Henry G. View Post
Royal Purple is average stuff at best. Read the technical reviews.
Redline MT-90 is top notch stuff. This is a 15 minute job at worst if you have the right tools. You will notice smoother shifting and that grinding while going into reverse will all but disappear. Its a no brainer especially if you drive 25k miles a year like I do.
If your grinding while shifting into reverse. Learn from your mistakes. Put the car into first gear then shift it in reverse. Grinding is due to the driver most of the time.
Have patience with your car and it will drive smoother.
This was to inform all on how to reduce grinding when shifting into reverse.
This was written respectfully as possible.
valchrist90731 is offline   Reply With Quote
Old 10-25-2015, 08:45 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I will be as respectful as possible as well. This issue with shifting into reverse with the stock or other conventional fluod is a known issue. Expecting someone to shift into first just to shift into reverse is unacceptable. Telling someone to be patient isn't a cure to the problem. Sure, it is possible that drivers are over anxious to shift, but the issue has even been noted in published reviews. Once again reviewers could be over anxious to shift, but they have experienced many many manual transmissions in most cases so they have firm ground to stand on regarding the behavior. I have driven a few dozen different manuals from various vendors and have experienced this only on well worn transmissions not brand new ones. I had the issue within the first 1000 miles. Changed to synth and bam, resolved. There is a reason why so many manufacturers are switching to even requiring synthetic; it is a much more tolerant and better working lubricant.
Sent from my SCH-I545 using Tapatalk
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
