![]() Drives: Toyota Yaris 2003 1.0 vvti Join Date: Aug 2014
3rd 4th & 5th gear rattle
i have a 2001 Yaris 1.3 CDX 5 door all is fine except it rattles in 3rd 4th & 5th gears it's done 90k it stops when you cruise in 5th but is there under acceleration, I have done nothing yet not even checked gearbox oil, any ideas ?😕
![]() ![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
Where is the noise and vibrations coming from?
Below you. Forward left or right center front? Gear oil for manual transmissions supposedly has to be changed anywhere from 30 to 60,000 miles. But i think it's not that. Are you the first owner? Last edited by valchrist90731; 07-24-2015 at 02:00 PM. |
Yeah first thing you do is get the gearbox warm (like before its winter) and drain that oil into a clean pan so you can examine it.
If you find a lot of metal in it (the oil has a metallic sheen) you've got a lunched tranny. Or if no oil comes out, ditto... If the oil looks OK put new oil in and see if you got the rattles. Also, get the car up on ramps and go over the underside of the car looking for loose nuts and bolts. You just might find something... Good luck and tell us what happens!
#4 | |
| 2nd, 4th & Reverse Gear Not Engaging | mesci | DIY / Maintenance / Service | 3 | 03-17-2023 07:03 AM |
| Experimenting with bypassing the AT 4th gear prohibition when cold | CTScott | Performance Modifications | 28 | 03-22-2015 08:16 AM |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
| No 4th gear in A/T? | caineroad | General Yaris / Vitz Discussion | 13 | 09-11-2009 06:47 PM |
| Yaris seems to get stuck in 3rd gear when going uphill | 47_MasoN_47 | General Yaris / Vitz Discussion | 16 | 08-24-2009 12:22 PM |
