#37 |
![]() Drives: Streak Blue 2015 Yaris SE Join Date: Oct 2014
I know this is an old thread but I have the correct OEM camera for the rear hatch... The black "block off plate" insert thing that has the two bolts holding it in place that is clearly shown in SineWave's picture: how the heck do I get that off? The nuts that are attached to the bolts when turned cause the bolts themselves to turn as well. What am I missing here?
#38 | |
#39 | |
![]() Drives: 2015 Yaris 5 Door Hatchback Join Date: Jul 2015
cheap car, cheap parts, cheap it is cheap it does (stupid is, stupid does) Let me know if you guys have had any issues removing this thing. Also have found this camera that may just bold on to this car.. http://www.ebay.com/itm/171593317287...%3AMEBIDX%3AIT been in touch with the seller and have provided pics and measurements of the black part that is on the car and he says this may fit. I have ordered it and should get it next week. I will let you guys know if it fits.. On that same note is there a harness that I can add an aftermarket cam to the stock head unit? I have the AXCP-Q15U (T10028) unit. Let me know, thanks. |
#40 | |
Anyhow I managed to take it off and just need some glue to add on the screws when I put it back in place so that the bolts do not spin as I tighten up the nut. |
#41 |
Also, tried to post a link for an after market camera but seems that my post have been deleted?? Don't know if im not supposed to link to ebay sellers but I see other people have done it so.
Anyhow I found a camera that may be a direct fit for this and I have been in contact with the seller I have sent him pics and measurements of the cover and he said that the one I ordered should fit. I should receive it next week I will let you guys know if it fit. On that same note, is there a harness that I can use for a stock radio for the 2015 Yaris LE? Thanks. |
#42 |
Update on the camera I purchased.. OK so I got the camera and no it does not fit properly it is not even long enough to reach the outside where the opening is on the plastic molding. So I tried to get another one that has a longer neck. Here is the ebay auction if you guys are interested.
http://www.ebay.com/itm/171593321191...%3AMEBIDX%3AIT I will see if that works. and let you guys know. What is the part number for the stock rear view camera and how much will it cost from the dealership any one know? Last edited by OGHUGO; 07-22-2015 at 09:52 AM. |
#43 |
OK, while I wait for the new camera to arrive I wanted to start wiring my in the stuff I will need. Does anyone know where the wire for the reverse light is? Need to tap in to that for the head unit to properly display the camera when in revers.
Thanks in advance. |
#44 | |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
http://www.aliexpress.com/item/SONY-...536788227.html This is the harness I bought and it worked well as well. http://www.autoharnesshouse.com/19867.html Very easy to install http://www.autoharnesshouse.com/1/pr...amera_conn.jpg Everything is plug and play except the reverse trigger wire where you have to plug in to the 28 pin connector on the back of your head unit and splice it to the reverse wire either on your ECU or reverse lights. http://www.autoharnesshouse.com/19867_add.html Let me know if you have anymore questions. |
#45 | |
Man thanks for the info, however how is it that the camera you got was a perfect fit? did you leave the hole in the car after the install? that looks like it will just fit on the molding but doesn't seem like it will cover up the home that is left on the actual door. I want something that is going to go bolted on the 2 bolts and goes straight outside sortha like the actual factory one with out having to pay factory prices. Also where is the wire for the ecu that I need to tap into? Thanks again. |
#46 | |
I didn't tap to ecu because I didn't wanna mess around with it, tapped the reverse trigger wire to the reverse light red wire :) |
#47 |
Ok, so i got the other camera and no go still does not fit. now its like $65 for the cost of both cameras and no go. I talked to the seller and he said he can refund if I return them but have to pay for shipping to china.. I have given up on trying to find one that is like the oem and got one like the one you got UCSMFU but got it from a us seller for $23 rather wait a few days than a couple of weeks.
Now I have everything ran all cables but need to get the right cable for the reverse trigger. Does someone have pics of where this is located? Thanks. |
#48 | |
http://www.yarisworld.com/forums/showthread.php?t=52850 |
#49 | |
Also tried to remove the covers and they hard as shit to remove. |
#50 |
#51 | |
Drives: 2015 yaris Join Date: Jan 2015
#52 |
![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
I have a 2012 Se with retrofitted touch screen and nav. I bought the camera 86790-0D010 used from a parts house in Ireland. It just arrived, but I am trying to find the pigtail that goes from the camera to the hatch wiring. My wiring looks exactly as above. I can't seem to find the pigtail anywhere, or the wiring diagram for the hookup. Yes, I realize this is an old thread LOL
#53 | |
![]() ![]() Drives: 2017 Yaris SE Blue Streak Join Date: Aug 2017
should this work on the 2017 se? I have a camera already similar to the beatsonic style just to get it plugged in, will standard cameras work? or will the view be off as it off to the side? |
#54 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Here's the camera I fitted. It was listed on eBay as fitting a Camry. It plugged into the hole from outside. It needed sealant around it as it is smaller that the opening (same width but can slide forward and back).
Also a pic of the view from the camera of my other car behind the Yaris in the driveway.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
